1969 Splash Shield
I've tried to research using cars posted for sale, but I see very few serial numbers as late as mine, and the ones I do see don't have pictures of that area.
Thanks in advance. I don't post much, but I do use the past posts a lot.
Tom
My 69 is an April build and it has white plastic shields on the lower firewall and parkerized metal shields under the floor plans. I bought new plastic toe shields from Paragon and had my original metal shields re-parkerized by somebody out in Cal. Not cheap. Are you replacing insulation?
Dennis the Rat
I don't currently have any insulation between the floor pans and the fiberglass. When I research that, it seems like there is suppose to be some rivet holes on the firewall where the grommets attach, which I don't have (either grommets or holes). I see pictures of cars that have insulation all over, and some that have very little. I'm not sure what I'm suppose to have, or where it's suppose to attach. If you could give me some guidance, I'd put it in there.
Also, I'm not sure what the "parkerized" means. My pans aren't in any condition that I would have them recoated. They've been straightened in the past, so if I bought them new, would they come with the correct look?
Tom
Here is a picture of the firewall with the double-pointed insulation clips riveted thru the fiberglass. I have also included pictures of the insulation and shields installed. Please note I have since corrected the shield installation to show the white plastic shields in front of the metal shields. The 1969 AIM (Assembly Instruction Manual) on page J85 shows the metal shields and shows no revision date that would eliminate them. Parkerizing is a manganese phosphate protective coating. My shields were bent and the restorer straightened them. I could not find the plastic shields in the AIM but still have my originals that were badly discolored and damaged. The shields are there to protect the insulation. I do not have the latest NCRS TIM & JG to see what they have to say about when they were eliminated.
I'll have to look a second time, but I do not think my car has the double-pointed insulation clips. I'll check again in the morning. If they were there and now are not, there should be holes or patched holes where they once were.
I did not mean to imply that I thought the metal underbody shields were eliminated.....the plastic splash guards were changed to metal at some point in late 1969 and they remained metal (I believe) throughout the C3 production run. I have plastic, but I consider a September Corvette a "late" production car, but I'm beginning to think that my plastic shields are original and correct for the car.
I'm going to have to look into that parkerizing. This is the first time I've heard of it. That's cool that the restorer straightened yours....I think mine are beyond that. Mine are actually wrinkled slightly. I'm not sure what impact in the past could have caused it, but I'm probably going to have to replace them both.
Where did you get your insulation if you don't mind me asking? Does it come already cut or do you have to cut/shape it?
The switch to the metal toe shields from the white plastic took place very late in production. I would think a Sept 1969 built car would have come from the factory with the white shields.
The under body insulation was not used on all cars in 1969. It was dropped mid production. If you can't find evidence of the clips to hold it on your car it probably didn't have it from the factory.
After the the under body insulation was removed the large rectangular shields under the seats that were meant to protect it continued in production for a while. They no longer served a purpose and I believe they may have been dropped completely by the end of production. This would have been very very late in the model year if it occurred.
The large rectangular shields came from the factory either parkerized or painted semi gloss black. You could go with either and be correct.
I'm not sure exactly when all these changes took place, but an original owner on the NCRS website with a Sept. 1969 reports his car had the white shields toe shields, no insulation of the firewall/under body, and with the rectangular shields under the seats.
John
Thanks John for the information about the insulation. It thought it was weird that someone would have removed the clips and insulation with no evidence of either. Mine must be one of the cars that didn't come with the insulation. And thanks for the color of the metal shields. When I was sanding them, I thought they looked like they had evidence that they were once painted black. I think I'll go with that since it seems original to my car. The post from dmaxx3500 seems to confirm this.
Tom
