1978 GEN Light on the Dash
Old Dec 3, 2018 | 10:11 AM
chstitans42's Avatar
chstitans42
TheCorvetteBen
Default 1978 GEN Light on the Dash
Working on a 1978 Coupe. The battery is new, and the alternator puts out 14 V when the car is running. GEN light on the dash is intermittent, sometimes is on other times it isn't. Thoughts?
Old Dec 3, 2018 | 06:32 PM
Big2Bird's Avatar
Big2Bird
Alternator issue. Usually regulator. Testing will not always pick up on it.
Rebuild it or get a rebuilt.
Old Dec 3, 2018 | 08:53 PM
chstitans42
TheCorvetteBen
Id rather not throw parts at it and hope it fixes it. Are there any other tests I can do before I take the plunge on a new one?
Old Dec 3, 2018 | 10:52 PM
carriljc's Avatar
carriljc
Acquire the below info and post back:
1. Take a voltage reading at the battery terminals with the car off.
2. Start the car and take a voltage reading at the battery terminals with the car running.
2a. Monitor and document voltage changes if and/or when the voltage changes when the generator light illuminates.
2b. Monitor and document voltage at the alternator terminal output lug.
Report these back and we can start eyeballin' what's going on.
PS- you can get the alternator tested for free at your local Autozone/O'reillys/whatever place. If everything above looks ok, then I would suggest that. My local autozone will even do it on the car...so if you have a local autoparts place nearby, and a fully charged battery, you may want to do this.
Old Dec 12, 2018 | 10:19 PM
chstitans42
TheCorvetteBen
Just to update the thread in case someone searches for it in the future. I installed another alternator (used but good) and the light is out. Funny thing is, the one I removed from the car was a reman unit (bad sign) with a red mark on the bottom (worse sign). The one on the car now is an original GM Alternator and works wonderfully.
To 1978 GEN Light on the Dash
