Trivial scissor jack question
Old Dec 11, 2018 | 03:36 PM
fastimes's Avatar
fastimes
St. Jude Donor '19-'20-'21-'22
Default Trivial scissor jack question
I cleaned up the jack compartment on my 72, and freshened the paint on the jack, lug wrench and spring.
Now that it's all clean, I'd like to know if there is a certain way it should go back in the compartment.
I know the jack goes into the indent in the base, but is there a certain place for the lug wrench? It has the rubber anti-rattle bumper attached, but otherwise floats around loosely.
The spring only holds the jack itself.
I know it's a "non-problem" type problem, but I'd like it to be secured correctly.
Old Dec 11, 2018 | 04:06 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The lug wrench slips into the jack. I believe the owner's manual has a pic of it. Rubber grommet goes over the lug nut end of the lug wrench.
Old Dec 11, 2018 | 10:23 PM
general ike's Avatar
general ike
2017 C3 of the Year Finalist
St. Jude Donor '20- '21
Here you go Fastimes. You can see the jack handle inserted into the jack. Not the best pic but hopefully it helps!!! Ike
Old Dec 11, 2018 | 11:24 PM
fastimes's Avatar
fastimes
Thanks General!
To Trivial scissor jack question
