Removing (front) spark plug wires
Old Dec 22, 2018 | 10:25 AM
Novusuhu's Avatar
Novusuhu
Default Removing (front) spark plug wires
Hey everyone
How can I remove the (front) 4 spark plug wires from the engine without destroying them?
It seems that the 4 wires on the front are between the engine block and the motor mounts...
Old Dec 22, 2018 | 11:20 AM
MelWff's Avatar
MelWff
remove the boots by spraying them with silicon and twisting them off
Old Dec 22, 2018 | 12:07 PM
Novusuhu's Avatar
Novusuhu
I tried it with one wire... the wire broke off the boot instantly...
Old Dec 22, 2018 | 12:22 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
You could loosen the motor mounts and raise the engine a bit.
Old Dec 22, 2018 | 01:39 PM
ralphspears's Avatar
ralphspears
Banned Scam/Spammer
Remove the boot from the end that plugs into the distributor cap and pull the wire through the motor mount.
Old Dec 23, 2018 | 09:32 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I tried both ways, its easiest to loosen a mount and jack the motor up a hair and slide it through
To Removing (front) spark plug wires
