U joint solid or with grease nipples
Old Jan 4, 2019 | 07:01 AM
robmat's Avatar
robmat
Default U joint solid or with grease nipples
Hi there, I am restoring a 1973 Big Block corvette, and was wondering what type of U joints I should get for my drive shaft and half shafts.
Should I get the ones with grease nipples or solid ones? The engine is stock so there are no massive HP also its a 4 speed.
Any comments would be appreciated. Thanks
Old Jan 4, 2019 | 07:20 AM
Gordonm's Avatar
Gordonm
Solids are stronger for sure but a stock 73 BB does not have a lot of power. Either one should work as long as they are quality joints. The cheap ones are cheap for a reason. Crappy ones weather solid or greaseable will break.
Old Jan 4, 2019 | 12:14 PM
jackson's Avatar
jackson
All three quality:
Dana-Spicer
Neapco
Moog
Old Jan 4, 2019 | 01:10 PM
v2racing's Avatar
v2racing
I would go with a solid Spicer. Although there is not big HP in a stock 73 BB, there is a lot of inertia in the big crank, and heavy stock flywheel/clutch and dampner. Drop the clutch with a bit of RPM and there is a lot of force there. The solid spicers are not going to wear out because they aren't greasable with the limited mileage that most of these cars get. IF you do decide to up the power on your engine at some point, you won'y have to worry about the u-joints.
Mike
Old Jan 4, 2019 | 02:56 PM
HeadsU.P.'s Avatar
HeadsU.P.
Solid Spicers, for safety. Your *** is just inches away from a spinning shaft. If a U-Joint breaks, where do you think that shaft is going to go surrounded by fiberglass?
Old Jan 4, 2019 | 06:08 PM
robmat's Avatar
robmat
Thanks for the info
Old Jan 5, 2019 | 04:28 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Greaseable u-joints are very difficult to grease, you need a needle point extension on the grease gun and you need to rotate to half shafts and driveshaft to expose the fitting to be able to get the needle point in. T
Old Jan 5, 2019 | 09:22 AM
cor66vette's Avatar
cor66vette
C3 of Year Finalist (stock) 2019
C2 of Year Finalist (stock) 2019
Originally Posted by terrys6t8roadster
Greaseable u-joints are very difficult to grease, you need a needle point extension on the grease gun ...
Yup, I tried greasing them with one of those side greasing adaptors, and that's still a no go. Can you recommend a decent needle point extension? Thanks
Old Jan 6, 2019 | 05:03 AM
terrys6t8roadster
'Lincoln' they make lubrication equipment. And in my opinion it is the best equipment available. T
To U joint solid or with grease nipples
