I have owned several Pontiac cars 77-79 among other v8 cars (Mustang 5.0). I am a BIG Corvette fan (drove a couple but not my own) and have an opportunity to purchase a 73' 454 manual transmission Corvette (the way it came from the factory). It's in decent shape, most likely not the original 454 but a 454 nonetheless (with the original transmission). It drives good but needs interior restoration. The exterior color is red though it seems that it originally was blue.
They are asking $7k firm and I was the second person to respond to the sellers ad. I have looked around and $7k seems like a real good deal.
I asked why they are selling and they stated that the Corvette was part of a deal they made (it came with a classic Porche they purchased). They are Porche car enthusiast hence the reason for a quick sale of the Corvette.
Again, it seems like a good enough deal. I have always wanted a 454 in either a Chevelle or Corvette and this opportunity came about.
Please chime in with any advice. Also, how do I confirm it's a 454 engine?
Thanks in advance.
Reason: Add photos
Pad in front of the right cyl head. Clean it up and google the numbers. Definately a big block though. There are no disappointing big blocks. Now, research birdcage rust and check that and the frame. You want to pull the kick panels inside in front of the doors. And look at the windshield frame closely. http://www.corvettec3.ca/rustpics/index.html
also if you look down between the firewall and the engine on the drivers side you will see a casting number on the block. . it should read 3999289. if it does it is the correct 454 block for this car. the numbers on the front passenger side of the block will tell you if its the born with engine. the last few numbers should be same as the vin.
as far as a good deal I guess it depends on how much work can you do yourself. your looking at around 8 or 10 k to have it painted the correct way. at least here in pa.
does motor need to be rebuilt?
hows frame and birdcage?
interior parts are expensive as all other parts on a vette.
you can get a really nice 73 BB that will need nothing for low 20s to mid from what I have been seeing. although there were only 4412 made in 73.
for me I always buy the nicest one I can find. usually ends up being much cheaper and easier in the long run.,
I would try to get him down anothere grand or 2. good luck ,Nutsy
And if vin does not match, the larger stamping will tell you what vehicle, year, rated hp, etc. First letter is engine plant. Next 3 or 4 numbers month and year. 3 letters after that is the broadcast code that is details on what it was and what it was installed in. Remember, anybody could have changed crank, pistons, cam, etc. Code sez what it was, not what it is now.
The car runs very good so no rebuild needed. Worse case is I don’t have the time or money to keep, what will this car go for........ 454 BB, 4-sod, rust free car?
My opinion,
I would walk away from this car for 7k.
The paint is orange peeled and is that a crack above the lopsided Stingray emblem on the fender.
The interior is a mess and the shifter doesn’t look right to me.
Even the tail lights are wrong.
I looked at numerous 73’s before I bought mine and I would say a good price for this one would be in the $1500.00 range.
It would be a place to start if it was rust free, if you pulled the body and started a complete resto/mod and didn’t mind sinking $30,000.00 into it.
If you think it is something you will do a quick sale for a profit, it is my opinion you will loose a couple thousand just to get rid of it.
I looked at several much nicer 73’s for the price they are asking for this one.
Be cautious.
Is that a coolant fill cap inline with the upper radiator hose?
I've never seen that before is that a 73 thing ? :P
also, as said above? Unless its different than my 69, ins't there a bit of the shifter missing that allows you to go into reverse ?
Good catch! Why would they add this? I’m not familiar with a 454. I’ve been a Pontiac/Ford guy.
Car is worth a look right?
It does seem to have some issues. You might as well look at it. Definitely do some research on looking for rusty frame/birdcage.
If that paint job is as bad as people are saying, I would be worried they did a bad job trying to hide something.
Drove and hour out to view the car. The motor was stout but the holley carb needed some adjustments.
The interior is very rough and the body had cracks everywhere. If I dropped $10k-$12k on body work, I’d be close to $20k not including interior work.
I had to pass.
Thanks for all the advice........until next time.
I had to pass.
The next buyer (I was the first to respond to the ad) purchased the car on the spot. I assume if you know how to do body work etc, this is a great deal! Also think the motor (built 454) is probably worth $4k or so.
