Just trying to figure out a complete list of everything I should replace while I have the dash out of my 1981 corvette. I plan to replace the headlight switch, the wiper switch and the heater core. Is there anything else that I am missing that I should do "while I am in there?" TIA
Take a picture of your harness routing before you pull everything out
Install LED bulbs and better sockets
On my 69, I jumpered all the bulbs in two groups to make re-installation easier
The shift console on the early years is a big PITA. I made some mods there to make re-installation easier
Does your oil pressure gauge flicker? If so, change it.
The speakers will be trash.
You may need the two circuit boards. Heat kills them.
Did you buy a new dash? The original WILL crack when removed.
I would also get a new circuit board for the courtesy light timer. The old ones suck.
Changing out the ignition switch on top of the steering column isn't a bad idea, considering the original is 38 years old. Not hard to do, once you drop the steering column, which I imagine, you will. Make sure you get an AC/Delco or GM switch, when you do.
Especially if you pull the the bulbs to replace the flexible circuit boards, consider upgrading to LEDs. I have warm LEDs that look stock, have more light, and draw fewer amps. With the parts on your bench is the best time to test the circuit to make sure you insert the bulbs in the correct direction.
Also, the high-beam switch, on top of the steering column.
Thanks for all the suggestions, I have replaced the bulbs with leds the other day. I do not have a new dash, just want to replace all the old stuff that is starting to go. I do need to fix the oil pressure gauge and not 100% sure how to change the ign switch.
Willcox has a new oil gauge that does work well, and as good or better than a GM NOS.. Follow the directions included.
The dampening fluid in them dries up, hence the flicker.
The ignition switch is easy, and available at GM still. Tilt and non tilt are different numbers. Google Jim Shea steering papers and read up.
When you have the heater box out for the heater core, go ahead a buy a seal kit if you haven't planned to already, so you therefore replace all the seals associated with the heater box.
Are you replacing the headlight switch because it's bad, or just old? I would take a cleaned up original switch over a re-pop any day. Test the H/L switch vacuum valve for vacuum leaks. Clean up the electrical contacts with fine abrasive of your choice & coat with dielectric grease. When I need to repair a H/L switch if I need new parts for it, I use what I need from a new one and rebuild what's left.
A medical technician once told me buy a new gm switch for a camaro and swap the vacuum section.
The switch works, I think I will clean the old one up. I am also switching from vacuum to electric headlights.
I'm curious as to why you are doing this. Is it for weight savings? Fixing the vacuum leaks will make the car run better, of course, but the vacuum system is pretty cheap to fix.
