How to save my build sheet?
Old Feb 20, 2019 | 11:17 AM
crawfish333's Avatar
crawfish333
CI 6-7 & 9 Veteran
Default How to save my build sheet?
A couple of years ago, I was able to retrieve the build sheet from my gas tank. I replaced the gas tank and half of the build sheet came off. The other half is stuck to the metal on the tank. I had the piece of gas talk cut and the other half is now just stuck to a small piece of the sheet metal from the old tank. Both the piece that was removed and the pieces stuck to the sheet metal are very fragile and when I try to touch them they just crumble. I am wondering of anyone knows how I can preserve this document, or should I just take photos of what is left of the build sheets, print it, and call it good.
Any ideas would be appreciates.
Old Feb 20, 2019 | 11:38 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Regardless of any other measures you might try, take photographs.
Old Feb 20, 2019 | 05:30 PM
general ike's Avatar
general ike
2017 C3 of the Year Finalist
St. Jude Donor '20- '21
There are various ways of saving crumbling paper. One that I did to save a old clock label is to thin out Elmers glue and slowly "paint" it on the paper to saturate and reinforce it once it dries. You may need to add a backing of some other acid free paper. Was there anything written on the back of these tanks sheets?
Now I am not saying this is what you should do but you can search the internet for various ways of salvaging old paper and decide for yourself!!!
Ike.
Old Feb 21, 2019 | 11:04 AM
crawfish333
CI 6-7 & 9 Veteran
I do not know because it is currently impossible to turn the sheet over without it crumbling. It is extremely fragile.
Old Feb 23, 2019 | 10:22 AM
caskiguy's Avatar
caskiguy
Acid free sleeves
https://www.staples.com/Staples-Boun...product_277772
Old Feb 24, 2019 | 12:45 AM
firstgenaddict's Avatar
firstgenaddict
RARE BOOK CONSERVATORS...
This is where to start, they will rehydrate the paper, neutralize it and then mount it.
There were a number of articles on the NCRS site.
To How to save my build sheet?
