Paint color harmonic balancer, and position
Old Feb 23, 2019 | 06:57 AM
Novusuhu's Avatar
Novusuhu
Default Paint color harmonic balancer, and position
Hey everyone
I will paint the harmonic balancer with POR15 engine enamel (with a brush, engine is still in car).
- What is the correct color for the balancer? Black or orange?
- What color do you guys paint the 'signal stripe' on the balancer, and the timing 'arrow' (don't know the name) that points to the balancer?
I think got another issue... yesterday when I was removing my crank pulley, I had a hard time getting it off... The pulley and balancer were attached to eachtoher with a centre bolt + spacer.
I turned and turned to get the centre bolt loose. I finally got it loose by using a pulley belt around the crank pulley to hold it in place.
-Now my second question is: Is it a problem that the harminic balancer turned a few times? Do I have to get the 'timing stripe' back to the '0' mark on the arrow? Or can I just put everything back together and leave the position of balancer as it is, when starting the engine?
(Sorry if this is a stupid question, but I'm still learning so...) I just don't want to brake anything when starting my engine.
Old Feb 23, 2019 | 07:34 AM
derekderek's Avatar
derekderek
The harmonic balancer turned because the engine was turning. Unless there is no key in that key way slot you can see in the bottom pic. Wait a minute. You grabbed the outside of the balancer with a rubber strap wrench. And then you loosened the balancer bolt. Did inside of the balanceer turn while the outside of the balancer stayed still before the bolt came loose? If so, throw the balancer away. You need a new one.
Old Feb 23, 2019 | 08:51 AM
HeadsU.P.'s Avatar
HeadsU.P.
dd. relax. You are jumping to conclusions again.
Old Feb 23, 2019 | 12:17 PM
Novusuhu's Avatar
Novusuhu
The inside of the balanceer did not turn while the outside of the balancer stayed still before the bolt came loose.
Before I had the pulley belt to hold down the pulley from turning, I turned the engine I think... I heard a Pffff sound everytime I turned it around....
Did I brake something?
Can l just paint the balancer, and turn the engine on without worrying about the place where the timing mark was (when turning the engine by hand)?
Old Feb 23, 2019 | 01:05 PM
HeadsU.P.'s Avatar
HeadsU.P.
Absolutely! Just make sure its thoroughly cleaned before painting.
Your timing mark can be repainted white with a fine artist brush.
Your pulley can be spray painted engine satin black.
Old Feb 23, 2019 | 06:21 PM
derekderek's Avatar
derekderek
No, you didnt break anything. Is either valve cover off? You can check timing mark against the rockers on 1 and 6. Not precise, but will tell you if it is within a couple degrees of where it belongs.
Old Feb 23, 2019 | 06:41 PM
HeadsU.P.'s Avatar
HeadsU.P.
Let your new paint job dry, then start it up. Hell of a lot easier than worrying about pulling valvecovers, scraping off gaskets, buying gaskets, installing gaskets, checking rockerarms.
After it starts, shut it off, attach your crank pulley, torque the bolts, reinstall the belts, tighten belts and drive!
Old Feb 23, 2019 | 09:12 PM
Novusuhu's Avatar
Novusuhu
The valve covers are still on.
I'll try to figure out what you mean... Sorry I'm just not an expert like you guys. Do you mean that the timing mark has to be 10 or 2 o'clock (just a guess of what I think you mean)?
What would happen if I just put everything together and drive it, with the position of the harmonic balacer not changed back to the original position?
Old Feb 24, 2019 | 11:28 AM
HeadsU.P.'s Avatar
HeadsU.P.
What will happen? NOTHING! Drive it. Enjoy! Your task is done here.
One of posters on here thinks the outer ring of the balancer moved separately from the inner hub just because you unbolted the unit. What you meant to say is, you squeezed the fan belt to hold the balancer while you removed the bolt. Good for you. That's a good trick that works 99% of the time. No strap wrench was ever used and I highly doubt anything is wrong with the balancer. Like I said Post # 7. Finish your paint job, put on the belts and drive it.
Your timing will STILL be right on the money, because you never touched the distributor. The key and keyway at the end of the crankshaft will determine if you installed it correctly. Don't worry about the timing mark. All you are doing is removing the balancer, painting it and reinstalling.
To Paint color harmonic balancer, and position
