So, if I...
Old Feb 23, 2019 | 02:01 PM
Skeetshooter's Avatar
Skeetshooter
Default So, if I...
...Purchase 17x8" wheels and order them with the factory backspacing, 4", (although I've seen a site stating 3.5"), and factory offset, -13mm they should fit as the OEM 15x8" aluminum wheels do?
I'm sure this seems like a really basic question but I obviously want to get things right.
Thank you as always.
Old Feb 23, 2019 | 03:00 PM
Skeetshooter
Actually could not it be argued that the OEM wheel do indeed have a 3.5" backspacing since the offset is -13mm which is a bit ver a 1/2 inch?
Old Feb 24, 2019 | 06:37 PM
MelWff's Avatar
MelWff
Regardless of the backspacing, depending on the type of wheel, you have to make sure there is clearance between the calipers and the "spokes" of the wheel. The manufacturer doesnt have an application specific program on their web site?
Old Feb 24, 2019 | 08:05 PM
Skeetshooter
Actually I did find a supplier of the wheel company that did have an app program and I guess they will. I'm still a bit concerned that with the 4.5" of backspacing the wheel may tuck in to far while still fitting.
Old Feb 25, 2019 | 12:47 PM
MelWff's Avatar
MelWff
assuming you intend to mount the same size tire, can you check the current clearance of the tire/wheel with respect to the TA arm and in particular the bracket for the parking brake? Do you have more than .5" clearance?
Old Feb 25, 2019 | 01:00 PM
OldCarBum's Avatar
OldCarBum
I purchased 17” x 8” with 4” backspace ET Team III wheels and fit checked them on my 73.
They fit perfect with no clearance issues.
Any more backspace and I would have to move the parking brake cable.
I would call the wheel manufacturer and tell them what you are fitting their wheels on and they should be able to tell you exactly what wheel will work.
Old Feb 27, 2019 | 06:27 AM
Skeetshooter
Thank guys for the replies. That is a good idea to measure then see. As carpenters say... Measure twice cut once.
To So, if I...
