I have the Zip kit.....when I got the car the tach was in but not wired.....easy three wire hookup just like a regular tach and it is within 100 rpm of my Bosch Timing light RPM reading.....which I consider to be pretty accurate as it is coming off the wire.
A must do upgrade on these if your cable freezes up and you can use any distributor you want.
Corvette America 1-800-458-2475 has new HEI tach drive distributors for $90. I discovered this while talking to their sales rep at SEMA last year and ordered one right away.
Jebby
I've owned my 74 since 1983 and went thru a few cables myself and when it wasnt the cable it was the distributor cross gear that drives the cable.There was even a period that I went without a tach..
redcruz1120....Where did you get these gauges? Who manufactures them?
They're vinyl overlays! from whitegauges.net they were only going to be temporary a few years back but I liked them so much i just kept them as they are!!
So, here is the low down as I see it on the conversions... If you own a 1968-1974 car you can purchase the conversion kit and it'll work fine. The major issue is that when you receive the kit's they are not calibrated properly.... and I mean this... they suck as far as calibration so you'll have to dial it in. (they have an adjustable pot on the board)
Do a zero set on the needle with power and ground, then install the needle... Then you'll need to calibrate the movement to the face. So install the kit, and before you put the dash back together hook up a dwell meter (set to RPM's) and dial in the pot on the meter. That's about the easiest way to do it unless you have a signal generator. I make the signal generators for the 75 and newer cars and they work great but who want's to spend 100 bucks for something they'll use one time when you can go buy a cheap dwell meter for a fraction of the cost.
