Firewall Grommets
Hood release cable grommet (found this on multiple sites)
Clutch linkage grommet (unsure of what should be in the car? Is this just a large plug with slits cut in it?)
Steering column seal (have this taken care of)
Speedometer cable grommet (found on a couple of sites, but I'm unsure of how to get it over the cable ends?)
Headlight vacuum hose grommet (should this be a 2 hole? It appears that the reverse light switch wires also run through this, but they are actually between the grommet and the firewall instead of running through the rubber grommet?)
AC wiring grommet (unsure what I need for this)
Heater / AC vacuum line grommet (this should be a 3 hole correct?)
Is there anything I'm missing from this list?
Thanks for any help!
Adam
Headlight vacuum hose grommet (should this be a 2 hole?)
Adam
