The winter project got off to a late start...really late. haha. Going to do a transmission\clutch rebuild. Please let me know if I am missing anything or I have the wrong part.
I wanted a parts check. One of the things I am really confused about is which clutch\fly wheel I need. 10.5 vs 11" and the number of teeth. I am going original, but I don't know what is on the car. I called two stores, one Corvette Central and I don't recall the second right now (brain fart) but they told me different things. From Rock Auto:
- Transmission mount: PIONEER 622378
- clutch kit: AMS AUTOMOTIVE 04504 (assuming 11"\26T)
- flyweel: AMS AUTOMOTIVE 167654 (assuming 11"\26T)
- flywheel bolt: ATP ZX2196
- universal joint strap kit: DORMAN 81000
- universal u bolt kit: GMB 2600121
Not 100% sure I trust that info. Shows a 10.5" clutch with a 168 tooth flywheel which would make me pause. Possible??? yes. Likely??? I would have to open it up to believe it.
If you post the number cast into the aluminum bell housing I would feel better about making a call.
Can I see that without removing everything?
Any what would give you hesitation? Is something not good about the 10.5?
The mix of a "large" flywheel with the "small" clutch is why I do not trust that Chart Information. 168 tooth flywheels are used with 11" clutches and 153 tooth flywheels are used with 10.5" clutches.
Nothing bad about either size setup but you can not mix and match the combination. The chart data is suspect.
To verify your setup - The starter nose cone bolts are either "in-line" with each other or they are "diagonal" with each other. Diagonal bolt pattern is used with larger 168 bolt flywheel and 11" clutch setup. The in line bolt pattern is used with the 153 tooth flywheel and the 10.5" clutch setup.
Or you can find the bell housing casting number visible on the outside of the casting. That would also help to confirm the size of your flywheel/clutch assembly.
Would it require extra work or cause any strain if you ended up putting a different one in that wasn't the same as the original? Say it came with a 10.5\153 but I put in a 11\168. Would that cause any issues or fitment problems, need to do something extra, etc. Especially if I am buying the rebuild kit mentioned above.
No way would I change the setup. No real benefit to you. LOTS of parts (EVERYTHING) and lots of cost to change it.
The next step is check the starter bolt pattern and/or the casting number. Just take a minute to look under there. No disassembly required.
Last comment - Hypothetically...if you wanted to change the setup from what it came with for some reason - the disk, pressure plate, bell housing, flywheel, starter, and starter brace would ALL be REQUIRED to be changed.
Can't say with 100% certainty without looking but I would GUESS you have the larger setup originally. Certainly need to verify before ordering any parts.
The difference would be if your flywheel is drilled for both size clutches. Some are not. And some bellhousings are smaller internally and the 168t 'wheel won't fit there either. That's the deal on the casting number on the bellhousing.
Cant put small flywheel in big bellhousing. It would fit but starter will not reach deep enough to reach the ring gear. Bell housing only accepts one starter nose, not both so the combination does not work. Somone always chirps in about dual bolt pattern starter noses and that does not work either.
Here is what I got. I wasn't sure where the bolts you were referring too were located, so I took a few pictures. But I believe I got the casting number.
