C3 1976 L48 engine
Old Mar 31, 2019 | 09:58 PM
Luis Soto's Avatar
Luis Soto
1st Gear
Default C3 1976 L48 engine
Why my car wear the air conditioning belt in a very short time?
Thanks for your help.
Old Apr 1, 2019 | 06:55 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Pullies out of alignment. Wrong pulley. Wrong belt.
Old Apr 1, 2019 | 08:11 AM
HeadsU.P.'s Avatar
HeadsU.P.
I would suspect a wonky compressor. Either its bearing is seizing, lack of lube, or its locking up when it shouldn't. Remove your belt and see how easy the A/C pulley is to rotate.
Old Apr 1, 2019 | 01:49 PM
L-46man's Avatar
L-46man
1. Pulleys MUST be directly in line with each other.
2. Belt(s) MUST be of the correct size.
3. Belts are designed to RUN on the V-groove (walls) of the pulleys...NOT the BOTTOM of the pulley groove. Ideally about half-way.
4. Glazed pulleys will skid the belt.
5. Run-out, wobble, MUST BE CHECKED.
6. Do not take the MFG's word on belt sizes....measure them against the spec.
7. Tension the belt in the old tried and true 1/2 inch of deflection across the LONG AXIS between the pulleys.
8. People over-tighten belts thinking more is better....this wears out the Alt and W/P bearings quickly. Rather a little looser is better...see #7.
Good luck..
UnckaHal
To C3 1976 L48 engine
