Shakedown.
Old Apr 3, 2019 | 07:21 PM
DJ74's Avatar
DJ74
Default Shakedown.
Transferred the title and got plates today and officially went on my first run. Found a few things that I didn't catch on the test drive.
Below is my current list - Its short right?
Speedo don't work
Odo don't work
Horn don't work
Already have a deleted radio
Steering just a bit sloppy.
Noticed today my dash was painted from red to brown
pop up lights need new rubber boots
Other than that it was a great day. Lots of thumbs up on the way. Got used to shifting after a few blocks (been 20 years since last time I drove stick)
More shows this summer - maybe a little less walleye.
Old Apr 3, 2019 | 08:19 PM
kdf1986's Avatar
kdf1986
Hello
that is a short list. Give it some time and it will surely get longer! Your off to a good start with a good shake down cruise and lots of thumbs up. Enjoy.
kdf
Old Apr 4, 2019 | 06:58 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Wheres our pics??? YOu are such a tease........
Oh and by the way, Welcome aboard!!!!
yes its a short list, your speed o cable could be disconnected, broken, the plastic gear is stripped or the drive gear fell off inside the transmission.
Horns can be a pain in the ***. It could be the relay, a fuse or they are full of dirt and just need to be cleaned out.
The sloppy steering might be able to be tightened up by turning the lash screw half a turn in (do this last), you might want to pull the fill bolt on the top and pump in a bunch of grease too. You'll need a bolt with a zerq fitting in it or to buy one from Willcox. Check all your tie rod ends too, theres a lot.
If its power steering the control valve has side to side movent, its how the valve works. have fun with your new toy!!!
To Shakedown.
