Birdcages
Assuming that I cannot disassemble the car, weld up a new birdcage and put it all back together, what are typical options for this? Is it so expensive I may as well just double my budget from the get-go? Or could I find someone to do it properly for less than just buying another drivable car? I've seen plenty of reassurances about frame rust/softness but no one in the ads ever mentions that their birdcage is solid.
Thanks!
Chris
but keep in mind your total initial costs. not only do you have to consider purchase price, but consider shipping, insurance, sales tax, license and title fees, inspections and the other initial money you have have to put into a rusted car just to put it on the road. its a plus 20% proposition.
the correct repair is well into 5 figures by someone that has experience at the repair. add another 10K for the inevitable bodywork and paint that will be required.
almost total disassembly of the car is required with a year downtime.
and while it is apart, you should do this this this and this........
the only thing one would have going for them is the degree of rust. there are different ideas what this degree is.
If I required a zero rust car and found a car where the owner claimed a birdcage repair. I would want documented proof that it was repaired correctly.
so many folks paint over rust, others cut it out for a correct repair.
spend the extra money for a solid car. you won't regret it.
Later year c3s can be had in great shape for under $10K
Chrome bumper cars with T tops in my area start around $15K. I would get the best car you can for your budget. I started with a $10K budget and ended up with a $19K convertible driver with decent paint. It needed alot of hidden work that I found but didnt realize how much more was hidden. It was about $2500 to $3000 more with my own labor
Thanks!
Chris
Redvette2
The biggest concern: I want a drivable car that'll last 20 years with the kind of TLC that doesn't include dismantling the entire car for a year.
Redvette2
Coupled with this, I've seen birdcages in cars from the East, that have near perfect frames and cages, because they are stored in garages 24/7, and not used in the winter months. It's fair to argue thou, that cars that spend most of their life outside, and used on roads with salt during the winter months, could well have terminal problems. Cars used extensively in the East, on salted roads often rust from the chassis, upwards, including the lower birdcage, but still garaged every night, so it's quite possible, the windscreen frame could be fine.I've seen cars from the West with rusted out windscreen frames due to
being left out in the weather all the time, and often the lower cages, and frames are fine.
Only way to be sure is a thorough inspection, but it is fair to say that the older these cars get, the more difficult it will be to find a rust free example. Changing frames is not a horrid or difficult job, but birdcages is another thing entirely. With labour costs around $100 per hour(guessing here), rebuilding/replacing, will costs thousands of dollars, so one could easily overcapitalise.
Sorry for the rant, but it's a minefield out there
