1974 One Off Only Frame Data
Old Apr 29, 2019 | 07:41 AM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Default 1974 One Off Only Frame Data
Below I am posting two pictures for your review.
Both pictures show the rear section of a 1974 frame.
If you look closely you will see that in 1974 (first rear non chrome bumper cars) they added a section to the stock 73 frame to serve as a mounting point for a rear frame bumper. Meant to collapse in a rear end collision it is somewhat crude in design but a transition from chrome to rubber rear bumper. One year use only, then the rear of the 73 frame was changed to a 75 square back frame with shock absorber type setup.
If you have never seen one then here you go.
If you have seen them before then you will recognize this one.
First picture had the fuel and brake lines on it yet, second picture shows that these have all been removed.
Detail of the impact absorber section is easier to see in the first picture.
This frame is from my 1974 convertible and it is heading out shortly for eight new body mounts,new corner support gussets, a bolt extraction, and weld enhancements; after which it will be media blasted and powder coated. I will build back the frame to a rolling chassis and put it back up under my convertible as my 2019/2020 Summer/Fall/Winter/Spring project.
I just thought some of you might like to see an original 1974 frame rear section as it is unique.
I hope you find it helpful
Have a fantastic Spring.
David Howard
AllVettes4Me
Old Apr 29, 2019 | 01:29 PM
74_stingray's Avatar
74_stingray
C3 of Year Finalist (performance mods) 2019
St. Jude Donor '19
David, thanks for posting the 74 frame photos. I have recently had the need to tighten one of the bolts on the 74 rear bumper attachment.
Eddy
Old Apr 29, 2019 | 02:01 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Am I to assume that your "getting the suspension back on it in two weeks" plan has changed somewhat?
I am not surprised that it would be any less than perfect!
Old Apr 29, 2019 | 02:06 PM
74_stingray
St. Jude Donor '19
Is this frame getting the front cross member plate?
Old Apr 29, 2019 | 05:26 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
I had to wait for the opening in the schedule at my valued frame shop and they have an opening for me Wednesday so I am heading there soon and hope to have the frame ready to go soon. Then back to the chassis assembly, yes.
Old Apr 29, 2019 | 05:27 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
I have the front cross member plate for this frame already, yes. It has been powder coated and will be installed after the frame comes back from the powder coating facility as well.
Old Apr 29, 2019 | 05:57 PM
Gordonm's Avatar
Gordonm
David has case of “while your at its” real bad.
To 1974 One Off Only Frame Data
