Component Weights Requested
https://www.corvetteforum.com/forums...available.html
Does anyone know any of these weights?
- Rally wheel with tire
- Front spindle with caliper and rotor
- Rear trailing arm with caliper and rotor
- Halfshaft
Here's what I do know:
N90 wheels, with the heavy center caps, trim weights, and Goodyear Eagle GT II tires (255/60-R15), weigh 48.8 lbs.
YJ8 wheels, similar configuration (BFG Radial T/As, same size tire), weigh 49 lbs.
So, for the steel rallys, 57 lbs for an equivalent tire?
Brake rotor 15#
Brake caliper 11#
Front hub 8#
Rally wheel w/ trim 29#
BFG 255-60-15 31#
Bare Trailling arm 10#
T arm & hub 42#
T arm w/ rotor 57#
Half shaft?
strut rod?
a-arm?
