Window Crank Help Please.
Old May 5, 2019 | 08:50 PM
Al.'s Avatar
Al.
Default Window Crank Help Please.
Has anybody replaced the spring in the manual crank assembly housing ?
Im getting a chatter when I crank it one direction.
I drilled out the rivets and cleaned the cog and the spring and greased then put back together and it still chatters.
I did not remove the spring. Only examined it.
To remove it I would have to knock out this pin and further disassemble It.
This is the spring and I did order one.
I am not sure if the spring is good (I think it is ) Or if it is not in place correctly.
Any one with experience with this that and advise.
This is a video of what it is doing.
