73 AC question
Old May 6, 2019 | 03:06 PM
khigley's Avatar
khigley
Default 73 AC question
I have converted my 73 from R12 to 139A it has a new refurbished A6 compressor in stalled. Since the system was totally evacuated how many cans of 12oz 139A should I expect to put in it.???.. I have put 3 cans in and have no reading on the high pressure side, I also had a jumper on the compressor as I was putting the 3 cans into the system as I know the compressor will not run when it is low on Freon. I have checked for leaks and have none.
Old May 7, 2019 | 06:37 PM
MelWff's Avatar
MelWff
you have too much gas in there based on using less R134A than R12. Are you sure your gauge works?
https://www.classicautoair.com/recha...1975-corvette/
