C3 1982 fusebox
Old May 19, 2019 | 06:28 AM
paulr1160's Avatar
paulr1160
1st Gear
Default C3 1982 fusebox
where is the location of the fuse box
Old May 19, 2019 | 06:45 AM
Rotonda's Avatar
Rotonda
On the inside of the firewall, above and to the left of the brake/clutch pedal.
If replacing fuses, suggest you use the kind that light up an internal led when they blow. You'll spend a lot less time under there.
