Convertible top mount issue
Old May 21, 2019 | 09:28 PM
Beltran's Avatar
Beltran
Default Convertible top mount issue
I have stripped the mounting bolts on the passenger side. Well, one was already stripped the other is starting to soften now as well. Any suggestions on how to solve this problem. I don't seem to be able to remove the S plate that has the threaded holes to replace it. Short of using bigger bolts is there a better solution to this issue?
B pillar mounting holes for the conv. top.
B pillar Mounting holes for the conv. top.
Old May 22, 2019 | 06:36 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
you could drill and use a time sert. They are solid versus wound wire like a helicoil. very pricey but maybe your best bet if you want to use the same bolt
https://www.bing.com/search?q=time+s...ZI&form=MOZLBR
Old May 22, 2019 | 11:19 PM
Beltran's Avatar
Beltran
Ok. good idea.. but looking at the fictures to insert these things makes me wonder if I will get enough clearance to complete it.
Old May 23, 2019 | 08:00 PM
mrvette's Avatar
mrvette
My '72 driver side, I cut a hole midpoint on the door latch surface, allowing access to that hollow area where the bolts were placed.....removed the old nut/mounts, and made a plate of 1/4 inch steel and two threaded holes to attach the bolts holding the top through allowed for the positioning adjustments.....
covered my square hole in the door jamb with a piece of aluminum, glued in position.....
Old May 30, 2019 | 12:15 AM
Beltran's Avatar
Beltran
These worked. got them in tonight.
Old May 30, 2019 | 07:02 AM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
I'm afraid I am not enough of a mechanic or machinist to know how to make these work but having a convertible I sure may need to learn one day.
Any chance you found a U-Tube video or some other instruction to assist a guy like me that is willing to learn but unfamiliar with the process?
Thank you and glad you told us and found the solution.
Best regards,
David Howard
AllVettes4Me
Old May 30, 2019 | 12:50 PM
Rescue Rogers
They are just like using a helicoil. There is a second bit to chamfer the hole to to get the top of the insert flush with the metal surface. If I do mine I'll take a few pics. I know I have one that is close to stripped.
Old May 30, 2019 | 04:30 PM
Beltran's Avatar
Beltran
I did not use the chamfer bit. Could not get it in there without making the hole through the B-pillar huge. But it didn;t need to be exactly flush. it worked excellent without that step.
4 step process. Really quite simple. biggest challenge I had was that I did not have the bits that fit the tap, and then the tool to insert the 'insert'. These were the square ended tools. I had to improvise with slightly oversize sockets and an 8mm crescent wrench.
Old May 31, 2019 | 06:45 AM
derekderek's Avatar
derekderek
David there are a few youtube vids. here is the 1 minute version.
essentially a tougher helicoil.
To Convertible top mount issue
