Stupid things I did today.
Old May 23, 2019 | 11:21 AM
bmans vette's Avatar
bmans vette
St. Jude Donor '12-'13, '15- '16-'17-'18-'19, '21
Long time ago and a galaxy far away I was trying to impress my new gf by rebuilding the motor in her Chevy van.
Pulled the heads as 2 exh valves were burned. Took them to the shop for rebuild.
Decided to clean up rest of engine while waiting. Lots of crap, old burned oil, etc all over.
Get it all cleaned up. Swabbed the cylinders with some fresh oil. Figure I can turn engine over to get all cleaned out.
Starter is right there and I am working by myself. This was before remote starter switches. A big screwdriver across the solenoid contacts and I should be good to go.
Couple of rotations and I am doing good.
Forgot to put hose on fuel line to carb.
A couple of good squirts and there is gas all over as I hit the starter.
Spark and gas.....yep!
Fireball fills inside of van compartment.
Got it out by smothering it with no real damage to van.
For me....not so lucky.
Eyebrows gone. Eyelashes fused. Front of my hair singed. And a nice sunburned look.
Got the heads back in a couple of days and finished rebuild.
Old May 23, 2019 | 11:47 AM
Bergerboy's Avatar
Bergerboy
BUT.....Was your girlfriend impressed????
Or did she find a new boyfriend with brows and lashes intact??
Old May 23, 2019 | 11:49 AM
sray454's Avatar
sray454
Filling differential on '72 Vette - no room under there for bottle and no lube pump. So - bright idea - use a short length on tubing on lube bottle to allow a little bit of elevation. Tube slips off and into diff - couldn't fish it out. Had to pull everything back apart to split diff cover.
mike
Old May 23, 2019 | 12:43 PM
PainfullySlow's Avatar
PainfullySlow
Ah, just remembered another one. Living in CT, working in MT. All my bikes were back in CT so since I was spending so much time in MT I bought a brand new GSXR so that I had something to ride out there. Blue/white with white wheels. Second day that I own it there is already brake dust all over the nice, white wheels so I start with wiping them down. Get on the front wheel, clean as much as I can then grab the wheel and roll it backwards....crash. Brand new bike on the floor. It had been years since I owned a bike with a kickstand..all my race bikes are on rolling stands and that is how you move them. I managed to push the new bike right off of the kickstand.
Old May 23, 2019 | 04:45 PM
bmans vette
Actually she was a hairdresser at the time so cleaned me up good.
40 yrs later and married now.
As to the if she is impressed...guess you'll have to ask her.
I'm in the doghouse right now.......
Old May 23, 2019 | 04:56 PM
Bergerboy's Avatar
Bergerboy
What image comes to mind:
Old May 23, 2019 | 04:57 PM
Dirty Dalton's Avatar
Dirty Dalton
Originally Posted by radiotexas
At the top of today's stupid things I did or thought I would do to my '70. I innocently thought I could simply screw my new speed-o cable onto the back of the speed-o by lying on the floor, upper body draped over the door sill and reaching up through and around the clutch, brake and steering column to the rear side of the dash.
"waiter, another serving of humble pie, please"
'shell shocked in Texas'
You have to take the seat out first. Makes hitching up the speedo cable a snap.
"LIAR, LIAR, PANTS ON FIRE!"
Old May 23, 2019 | 05:26 PM
bmans vette
All except the cigar......LOL
Old May 23, 2019 | 05:48 PM
L-46man's Avatar
L-46man
okay...I'll play....no Corvette Content here.
I've been a mechanic for 53 years...just loved it since I was a kid. I'm very careful and smart about what I do....er ah, NOT THIS TIME!
VW Scirocco....Timing hole is in the transmission, so you unplug a 'cap-plug' and THEN you unscrew the 2" diameter timing plug to shine the light on the flywheel for timing.
It's a little 'dim' in the garage (and my head apparently)....I reach down to remove the plug...ENGINE RUNNING....Hmm... plug won't come out....reach down FIRMLY with my right index finger into the timing hole....DOH! the PLUG WAS NOT THERE.....ZZZZT! like a Salad-shooter the timing boss on the flywheel machined my index finger down 3/8ths"...at 1000 RPM in 1/2 second.
It grew back....but lots of blood and it was touch and go for a while.
So if you have one of my old Sciroccos...there's a finger down there somewhere! (the Scirocco will give you the finger!)
Unkahal
Old May 23, 2019 | 06:37 PM
loup68's Avatar
loup68
Army
About two months ago, I disconnected my C-Tek battery charger without opening my driver door. I have a battery disconnect switch and I turn the **** and get no interior lights. I freak out and get my
heavy duty battery charger/starter. I go to hook it up and open the door for better access....and the interior lights come on. Duh!!! Yes I am getting old!. Lou.
Old May 23, 2019 | 06:51 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
When I was 18 , in the Navy with a new Honda interceptor. I was rebuilding the 455 In my 69 GTO at the Air Force motorpool rental area and had some time to clean up and Armorall the bike. ArmorAll the seats, the cables and the tires. Well you know if you spray the tires and let it soak in, it lasts longer and looks real good. Its just that the over spray that soaks into the treads gets a little slick. Well when you fall over at slow speed cause the front tire suddenly has a lot of understeer, the handle bars make a nice size dent in the tank ......
Old May 24, 2019 | 12:54 AM
bmans vette
Unkahal
Not a timing/flywheel story but one of my many restaurant stories from my chef days. Early in career I was slicing zucchini and yellow squash on a meat slicer for that day's veggie medley. Waitress came up to ask me a question while doing this. Of course she was pretty and distracting. Veggie slipped and the finger I was holding it with took its place. I too lost about 3/8". Took a while to grow back. I had to look just now to remember which one it was...lol
Old May 24, 2019 | 12:56 AM
  #33
bmans vette
And no one was watching when that happened. Right?
Old May 24, 2019 | 07:30 AM
  #34
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by Greg
Truth be told Scott, I'm sure others here have done much worse.
I know I have....
I've been messing around with cars for just about 50 years, and that has given me plenty of time to practice doing "dumb stuff"......
Old May 24, 2019 | 07:44 PM
  #35
Plasticfreak's Avatar
Plasticfreak
We're only human....born to make mistakes!
Old May 25, 2019 | 01:07 AM
  #36
bmans vette
And why flesh grows back after abrupt encounter with metal...especially hot metal.
LOL
