Body mounts
Old May 22, 2019 | 11:02 AM
C3 4 me's Avatar
C3 4 me
Default Body mounts
I'm going to be doing the breaks this weekend ...but when I was installing the carpet I noticed the previous owner changed the body mounts and they all seem loose I tightened the rear ones but I don't see how to tighten the ones in the bird cages and front ones ...I haven't jacked the car up yet ...so I will be doing so can anyone give me direction on the location from under the car I can see the top half just mot the lower half
Old May 22, 2019 | 11:31 AM
Tampa Jerry's Avatar
Tampa Jerry
The body mounts forward of the rear wheels can be accessed by removing the inspection door in the wheel well. Remove the four screws and you will see the top of the mount. The bolt goes through the body into a caged nut on the frame. If the bolt spins or does not move, it is most likely frozen or the cage nut is spinning. If that's the case, the bolt has to be cut or ground off and repaired. Best to get a copy of the AIM for your car to see where and how the body mounts are located. Some of the vendors have the diagrams on their web sites or in their catalogs. Jerry
Old May 22, 2019 | 12:13 PM
WARVETT's Avatar
WARVETT
The front ones can be accessed through the kick panels under the dash.
To Body mounts
