problems with rear c3 caliper
Old May 24, 2019 | 03:48 PM
Larry_50's Avatar
Larry_50
7th Gear
Default problems with rear c3 caliper
I replaced my rear disc/caliper which went well till I tried to install new pads,,had major trouble trying to clear caliper pistons which must of been sticking out a bit,,tried both ways,,installed caliper,,tried to drop pads in,,than installed with caliper,,finally got it,,but now it leaks,,is there a trick?? help,,,thank you,,i,m not a mechanic,,but now wished I had played one on tv,,,
Old May 24, 2019 | 04:12 PM
Tampa Jerry's Avatar
Tampa Jerry
I would addr
Old May 24, 2019 | 04:20 PM
Tampa Jerry
Sorry about the above. I would address the leaking caliper before going any further. Once the leak is fixed, I put the pads in the caliper without putting in the bridge pin. I use a piece of wood a bit thicker then the rotor and insert it between the pads. I install the caliper and push the piece of wood through the tip of the caliper. Once seated, I bolt up the caliper on the trailing arm and set the bridge pin in place with a fresh carter pin. Attach the brake line and bleed. Some people use an appropriate sized socket instead of the wood. Some of the vendors sell a tool to hold back the pistons, but a piece of wood is all you need. Good luck. Jerry
Old May 24, 2019 | 05:18 PM
mark79,80's Avatar
mark79,80
This tool makes installing the pads much easier:
https://www.zip-corvette.com/65-82-b...tion-tool.html
Old May 24, 2019 | 05:32 PM
bazza77's Avatar
bazza77
I use that sheet metal tool , just makes life easier , but as said wood block will do the job as well.
Old May 24, 2019 | 06:09 PM
Larry_50's Avatar
Larry_50
7th Gear
thanks jerry,,,,
Old May 24, 2019 | 06:12 PM
Larry_50's Avatar
Larry_50
7th Gear
thanks to all who responded,,,,,,,,,,,,,
Old May 25, 2019 | 10:05 PM
croaker's Avatar
croaker
What about the leak? You replacing or rebuilding? The seals are pretty easy to change
Old May 26, 2019 | 12:35 PM
Larry_50's Avatar
Larry_50
7th Gear
hi,,,just bought calipers few weeks ago....so I can get a refund,,
Old May 28, 2019 | 06:07 PM
kansas123's Avatar
kansas123
To problems with rear c3 caliper
