Front Rotors...
Old May 24, 2019 | 04:14 PM
Richard Cooper's Avatar
Richard Cooper
Default Front Rotors...
I am trying to replace my front rotors with drilled/slotted rotors. I have the caliper/bracket off and have drilled out the 5 rivets. I still cannot budge the rotor!! Could it be stuck on the center hub, there does seem to be rust around the hob/rotor. I have had it soaking in WD-40 for about an hour, but cannot move the rotor at all. I drilled out the heads of the rivets and then used a 1/2" bit to drill deeper and remove more of the rivet area. TIA
Old May 24, 2019 | 04:54 PM
MelWff's Avatar
MelWff
have you used a hammer to break off the rusted on rotor?
Old May 24, 2019 | 06:14 PM
PainfullySlow's Avatar
PainfullySlow
Very often rotors rust onto the hubs. You may need some 'persuasion' with a hammer to loosen them. I generally use a heavy rubber mallet but if you are tossing the rotors, some love taps with metal will likely free them up quickly.
Old May 24, 2019 | 06:41 PM
Richard Cooper
Thanks guys, got tired and gave up for today. Since I turned 74 I do not have the patience or energy I used to have, will try the hammer tomorrow. Have a great weekend.
Old May 25, 2019 | 12:22 AM
ronarndt's Avatar
ronarndt
There is a large puller that works if you need to remove the rotor without damage, but since you are going to replace them, get a big hammer and whack the crap out of it. I had to use persuasion to get mine off when I put the drilled rotors on my 68 convert.
Old May 25, 2019 | 01:17 PM
bmans vette's Avatar
bmans vette
St. Jude Donor '12-'13, '15- '16-'17-'18-'19, '21
Another vote for the BFH....after spraying PB2 in and around from the sides.
Not sure if I did that with last ones I tore down or used my press. Yeah, I am old too.....
But spraying Power Blaster the day before and letting it soak eliminates much frustration the next day.
Good luck!
Old May 25, 2019 | 02:43 PM
kingkohlmn's Avatar
kingkohlmn
Veteran: Marine Corps
Done you have to remove the axial nut? I have a 78, when I replace the bearing you have remove the rotor. At least that is what I recall having to do on the front rotors.
Old May 25, 2019 | 07:53 PM
Richard Cooper
Thanks everyone for all your help. I found a video on youtube that was a big help, it actually worked very well.
[font]
[/font]
To Front Rotors...
