Brake issue
Old May 28, 2019 | 11:11 PM
WillieB1956's Avatar
WillieB1956
2nd Gear
Default Brake issue
Looking for suggestions. 1974 Vette, 350 automatic.
Brake pedal is firm when engine is off. Once I crank it, brake pedal goes all the way to the floor.
Replaced vacuum line.
Does this sound like a booster issue ?
Thanks for advice.
Old May 29, 2019 | 07:50 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Its supposed to move down when the engine vacuum is apllied but not to the floor. Have you bled the system. Is the master new and didn't get bled?
Old May 29, 2019 | 08:42 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Be very careful....I damaged the front bumper area of my project car because of the same symptoms....good thing it happened in my driveway when the brakes completely failed....(no E-brake connected yet).
Old May 29, 2019 | 11:04 AM
WillieB1956
2nd Gear
Thanks for the suggestions. Next step is to bleed the system. Will replace the master cylinder too if necessary. I just didn’t want to replace the booster if I didn’t need to. I appreciate the shared expertise.
To Brake issue
