Frame stencil
Old May 29, 2019 | 07:16 AM
thelal1's Avatar
thelal1
Default Frame stencil
Why did GM stencil frames and number them in white paint. I was wondering,
Ted
Old May 29, 2019 | 07:40 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The stencil was applied at the A.O. Smith factory before the frames were shipped to St. Louis. Most contain the GM part number for the frame, an A.O. Smith lot number, and a date. Color could be yellow or white and the format varied a bit.
Old May 29, 2019 | 08:24 AM
thelal1's Avatar
thelal1
On my frame besides the stencil, there are numbers painted that I have found, numbers 1 and 2. What do they stand for.
Old May 29, 2019 | 08:51 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by thelal1
...there are numbers painted that I have found, numbers 1 and 2. What do they stand for...
Where are the 1 and 2? If they are close to body mounts, they probably indicate the number of body shims needed.
Old May 29, 2019 | 09:10 AM
thelal1's Avatar
thelal1
On the driver's side in front of wheel on straight of frame #2 above wheel to the rear on the frame over ,# 1 is painted..
I will take molding off today and post pics.
Old May 29, 2019 | 10:17 AM
thelal1's Avatar
thelal1
I was able to view frame stencil , its upside down. Number 3987882-110. Was this the frame number from A.O. factory?
Then above it is 2-5-71.
My car was built in Feb.71
Old May 29, 2019 | 11:30 AM
Easy Mike's Avatar
Easy Mike
You can Google the GM part number. 110 is likely to be the A. O. Smith lot number. 2/5/71 is the date A.O. Smith finished the frame. Your car should have a time built date after 2/5/71.
Old May 29, 2019 | 12:06 PM
fla-buckeye's Avatar
fla-buckeye
Believe that the stencil markings "1" or "2" were to indicate what shift they were built. Marking for shims were in crayon as in ///
Old May 29, 2019 | 12:16 PM
thelal1's Avatar
thelal1
Build date on trim tag was February 19th,1971.
Old May 29, 2019 | 01:04 PM
Easy Mike's Avatar
Easy Mike
...Build date on trim tag was February 19th,1971....
That works. What would become your frame was assembled two weeks earlier and shipped to St. Louis.
Old May 30, 2019 | 04:32 AM
hunt4cleanair's Avatar
hunt4cleanair
Ted
Also note that a different part number was used for each four-speed or automatic frame assembly to differentiate one from another as they shipped and stored at St Louis assembly plant. At the Corvette factory, workers would confirm the correct frame assembly for either a four-speed or automatic order as the chassis was built up.
To Frame stencil
