priming new engine
Old Jun 7, 2019 | 09:17 AM
68 beginner's Avatar
68 beginner
Default priming new engine
just about ready to start a 454 engine that has been rebuilt....do I need to prime the oil thru the engine before I crank?
Old Jun 7, 2019 | 09:26 AM
540 vette's Avatar
540 vette
Yes you do. I have an old distributor I modified to to that. I use a big drill to spin it. And I wait until I have oil pressure. Then I turn the engine 90 degees and do it again. I do this until I am back on top dead center.
Old Jun 7, 2019 | 09:32 AM
BLUE1972's Avatar
BLUE1972
be sure to use break in oil - not just plain oil...
Old Jun 7, 2019 | 11:30 AM
derekderek's Avatar
derekderek
A small cap HEI used from Ebay is a good one. Cheap and plentiful. Punch out the pin and remove drive gear. Nice thing about it is the rotor mount point is a small enough diameter to go easily in a drill.
Old Jun 7, 2019 | 03:37 PM
HeadsU.P.'s Avatar
HeadsU.P.
540 vette is spot on. Prime, rotate, prime rotate. Instead of an old dizzy, Moroso and some others make an oil primer tool, around $23. You can look at Summit for that.
Make sure you buy one with the collar that seals at the intake manifold.
It takes a hefty drill to spin and push that oil around. A corded unit is stronger and will not overheat as likely. It may take several minutes before you see any dribbles at the rockerarms.
Old Jun 7, 2019 | 04:59 PM
itsforfun's Avatar
itsforfun
I hope you used plenty of Assembly Lube on the lifters, push rods, rockers, cam, etc. As BLUE said, a good breakin oil with at least 1200 PPM of ZINC.
Old Jun 7, 2019 | 06:37 PM
Lyndwood's Avatar
Lyndwood
if you can borrow an engine oil pre-luber/ primer from the shop that built you engine that would be the best, my engine shop loans it to anyone who asks for it. you fill it with oil and pressurize it then release the oil into the block via an oil port. it forces oil threw the oil passages in the block the way it will when the engine is running. If you chose to do it with a drill buy a primer tool like the moroso or use an old distributor shaft as stated. If you use a long slotted screwdriver in a drill you will be only lubricating one side of the engine, you need the block off collar to split the oil to all the oil passages.
Old Jun 9, 2019 | 05:10 PM
68 beginner
Default priming engine
Thanks guys..I will get proper tool for this
Old Jul 11, 2019 | 08:29 PM
Jstan2014's Avatar
Jstan2014
Op, I just stumbled upon this thread. Did your engine break in take place and did all go well?
To priming new engine
