Can Someone Explain The Key Buzzer for 69
Old Jun 18, 2019 | 10:36 AM
69L46vert's Avatar
69L46vert
Default Can Someone Explain The Key Buzzer for 69
Working on some of the little things now and realized the car is supposed to have a key buzzer. Is it in the horn relay and just exactly when would it buzz? Thank You
Old Jun 18, 2019 | 10:46 AM
KingRat's Avatar
KingRat
Yes. It is in the horn relay and it will buzz with the door open and key in ignition. Mine wasn't working when I first bought the car. I opened up the relay and had to solder a wire inside. Its worked for 30 years now.
Old Jun 18, 2019 | 10:58 AM
nix1981's Avatar
nix1981
Yep, it's in the horn relay. It goes off when the key is in the ignition but you can make it turn off by just pulling the key out a bit.
Old Jun 18, 2019 | 11:00 AM
69L46vert's Avatar
69L46vert
Thanks for the explanation KR. I'm going to take a look at it today.
Thanks Nix
Old Jun 18, 2019 | 04:39 PM
69L46vert's Avatar
69L46vert
Popped the cover off the relay and it was a rusted mess in there. I lucked out when I found a spare in my loft from a 71 I used to own. I had the column apart in order to find out what was wrong with the horn. Jim Shea's papers were a great help. Horn and Key buzzer working as designed. Thanks for the help, Rick
Old Nov 12, 2019 | 01:04 PM
CrossedUp's Avatar
CrossedUp
My apologies for digging up an old thread but, if it's located in the horn relay then why are there separate parts listed for tilt/tele and standard steering columns?
Old Nov 12, 2019 | 04:16 PM
bazza77's Avatar
bazza77
because the activation switch is in the column .
Old Nov 12, 2019 | 05:10 PM
CrossedUp's Avatar
CrossedUp
Thanks bazza.
Old Nov 12, 2019 | 06:00 PM
Syl1953's Avatar
Syl1953
Please excuse my ignorance and laziness, is relay located on drivers side near wheel well? Thanks, Mark
Old Nov 13, 2019 | 06:58 AM
69L46vert's Avatar
69L46vert
That's where it is on my 69
To Can Someone Explain The Key Buzzer for 69
