Hey guys, I am working on restoring my 75...does anyone know how to mount the tail lights on a new true flex bumper? If I buy new retaining clips (old ones rusted/unusable), is there a way to just use those to reattach the housings? Or will I have to get creative? I have removed the old light supports and have read that the lights need to be bolted right on to the new bumper cover, I am just trying to figure out in advance what I need to accomplish this task.
thanks in advance, any help is greatly appreciated!
I think I understand what you did by looking at your album, that’s very helpful! If I am seeing it correctly, you used two retainers per light, one on either side of bumper material. I think what I will have to do is buy two retainers per light and just use the three bolts to secure the outside retainer to the inside one
I put a true flex on my 75 also, i went with the stock tail lights, but then changed them to bubble tail lights.
I can not remember how i installed either ones. Will have to check out some of my install pictures.
KenSny i am also interested in your procedure, have pm-ed you.
Just looked at your pics, looked like mine did, to the OP i did not have to purchase extra retainers.
I just used the parts from the old gm bumper i think.
...when I did my old '75's TrueFlex bumper 14yrs or so ago, I had to remove those original upright grey/black plastic pieces from the rearmost frame rail. The TF bumper is rigid enough itself to support the taillights. Another mistake I corrected was that I bought a hole saw larger than the hole that's there for the taillights. The bumper has holes that are slightly too small and it's common to see taillights that are tipped skyward because that is the way they want to tilt when tightening them down, which you can OVER DO!!! The taillights need to be just "lightly snug". I also remember removing that aluminum piece just behind the Corvette letters and had to shorten each of those vertical pieces on each side of the license plate area to get my bumper to fit.
Wow this helps out tremendously, I have removed those old light supports and the metal part in the middle of the bumper and still have a little fitment issue. I will try and see if there’s something I can do about those two metal “bumpers” on either side of the license plate. If the fit feels better after that, I may try and keep that metal part in the middle. I’m so close to finally driving it, this is the last big snag that’s holding me up... thanks again for all the tips and help! So much experience on here
