Coolant leak ....STILL!
Old Jul 10, 2019 | 10:49 AM
Kacyc3's Avatar
Kacyc3
Originally Posted by OLE442
So, I assume I could just leave the bypass hose between the water pump and the manifold on. It will still flow but is not perfectly round at the curve. Even if it were closed up completely, it would be doing the same thing as the Dorman caps? That would allow me to drive it until I check the heater core out for leaks.
Its better to plug it but the hose can get you by as a temporary solution till you locate and resolve the leak.Just dont let the hose rub on anything and wear a hole in the hose.
