Poly urethane rear bumper fastener help
Old Jul 11, 2019 | 10:51 PM
L82 crusin's Avatar
L82 crusin
Default Poly urethane rear bumper fastener help
hi all!
so im replacing the rear bumper on my 75' and snapped off a few of the bolts holding it on. with that being said new hardware kits from where im from run over a hundred dollars which i find quite obsurd. But ya my metal strips are in excellent contidition and i was able to tap out the old bolts just wondering if anyone knew what size/ type they were ?
thanks!
Old Jul 12, 2019 | 01:06 PM
derekderek's Avatar
derekderek
#10-24. or the 20 buck version. https://www.ebay.com/itm/73-82-C3-CO...s/153443823072
Old Jul 14, 2019 | 02:46 PM
mark79,80's Avatar
mark79,80
Same thing happened to me. I purchased 3/16” threaded carriage bolts from a local hardware store. After removing the heads of the broken studs, press the carriage bolts into the bumper brackets. The square flange on the heads of the carriage bolts holds them in place when tightening the nuts to secure the bumper:
Old Jul 14, 2019 | 09:21 PM
L82 crusin's Avatar
L82 crusin
Thanks a bunch!
Old Jul 14, 2019 | 10:34 PM
crf311's Avatar
crf311
You could put a little tack weld on the bolts
To Poly urethane rear bumper fastener help
