Help - Removing Radio Antenna
Old Jul 12, 2019 | 01:26 PM
70Yellowbird's Avatar
70Yellowbird
Default Help - Removing Radio Antenna
I've been trying to gently remove my '70 radio antenna from its base, but it won't budge. I'm hoping for some advice, tricks, special tools, lubricants, etc. that may work. There is nothing wrong with the antenna … I want to remove/reinstall it as part of my restoration.
Thanks in advance.
Regards,
Joe
Old Jul 12, 2019 | 05:31 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
I had to use PB blaster, let it soak, applied again, gentle rap, came loose. Take it slow and easy and you'll get it.
David
AllVettes4Me
Old Jul 12, 2019 | 07:07 PM
Daveinspain's Avatar
Daveinspain
Obsessed
2025 C3 ('68-'73) of the Year Finalist - Unmodified
Let me know how it goes. My 71 has a power antena that doesn’t go up. I had a new stock antenna delivered to the dealership to be place in the car before they shipped it to me. Now I will have to yank the power antenna out and install the new one.., I hope I can use the existing antenna wire that goes to the radio..,
Old Jul 13, 2019 | 12:16 PM
itsforfun's Avatar
itsforfun
SInce the top is weatherproof, getting any penetrant in is difficult. Spray heavily and often thru the bottom. When all else fails use a dermel tool to cut the bezel nut.
To Help - Removing Radio Antenna
