Antenna cable routing 73
Old Jul 22, 2019 | 10:48 PM
1973's Avatar
1973
Default Antenna cable routing 73
Hi, anyone know the routing for the antenna cable on a 73? Mostly towards the back where it routes through the body, thank you
Old Jul 23, 2019 | 12:22 AM
Eliredandblack's Avatar
Eliredandblack
After the cable leaves the connector above the alarm horn, it enters the cabin through a very large Grommet. My 73 is a convertible and the cable then follows the rear lights routed above the drivers side wheel hump, then down under the sill plate where it goes behind the drivers side kick plate. It runs above the plastic air duct, the below the speed/tach, and then above the radio where it plugs in on the passenger side.
Eli
Old Jul 23, 2019 | 06:16 AM
Tooch1's Avatar
Tooch1
From the '73 AIM
If you don't have the Assembly Manual I would highly recommend it !
Old Jul 23, 2019 | 09:55 AM
1973's Avatar
1973
Thank you!, Yes i do have a assembly manual, but not this page you show here, thank you, i bought a new harness and the grommet for it did not have a provision for the antenna cable
To Antenna cable routing 73
