Head Light Won't go Down
Old Jul 23, 2019 | 02:05 PM
Doug Keeling's Avatar
Doug Keeling
2nd Gear
Default Head Light Won't go Down
Does anyone know of a quick fix to get one of my head lights to go down. Want them both in the closed position until i can fix the problem
Old Jul 23, 2019 | 03:30 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Reach underneath and pull down on the center link.
Old Jul 23, 2019 | 03:39 PM
Doug Keeling
2nd Gear
Wow, that was easy! Hopefully finding the problem will be as easy! Cheers!
Old Jul 23, 2019 | 03:48 PM
Peterbuilt's Avatar
Peterbuilt
Default Hi and welcome!
http://www.corvette-101.com/vacuum.htm
Old Jul 23, 2019 | 09:07 PM
PGPierce's Avatar
PGPierce
Hanes Repair says Never try to close the door by hand.u might try to remove the vacumn hose to reduce any vacumn to the door. Or go under the nose with A pair vice grips and unhook the 2 springs on the rear of the assembly.
Old Jul 24, 2019 | 05:38 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Originally Posted by PGPierce
Hanes Repair says Never try to close the door by hand.u might try to remove the vacuum hose to reduce any vacumn to the door. Or go under the nose with A pair vice grips and unhook the 2 springs on the rear of the assembly.
Theres no need to go through all that, the hinge point in the center of the linkage is easy to deal with. Its very simple to do especially if you are dealing with the lights themselves. You more likely to get hurt or break something reaching up under there and trying to get those springs off. Thats like saying to replace your tires you should roll the car onto its roof.
People really shouldnt be going by the Haines manuals anymore. They havent been a good source of info since the 70's
Old Jul 24, 2019 | 01:24 PM
Peterbuilt's Avatar
Peterbuilt
As 'Easy Mike' said pull down on this part.
Be careful not to break the switch at #8.
To Head Light Won't go Down
