C3 72 exhaust donut ?
Old Jul 26, 2019 | 09:26 PM
Pitts532M's Avatar
Pitts532M
Default C3 72 exhaust donut ?
replacing heat riser valve on right side, figured I'd replace donut. Looking at diagram the donut fits between bolt flange and sleeve lip mounting to riser. How does that happen? Is there enough wiggle room to get donut over sleeve lip? 72 small block. Thank-you.
Old Jul 26, 2019 | 11:56 PM
Hammerhead Fred's Avatar
Hammerhead Fred
The donut goes on the sleeve an the sleeve is then pushed into the pipe. The flange then pulls the pipe + donut + sleeve tight against the heat riser.
Old Jul 27, 2019 | 09:20 AM
Pitts532M's Avatar
Pitts532M
Hamerhead Fred; thank-you that was what I was afraid of. I have not taken it a part yet, maybe it will become clear when I do, so please excuse my ignorance. The exhaust looks like it is a 2 ½ that reduces to 2” at the riser valve, so it seems I need a sleeve at the donut that fits into the exhaust.
Old Jul 27, 2019 | 05:03 PM
firstgenaddict's Avatar
firstgenaddict
IF you do not have the sleeve the donut will crush "too much" and will not seal up correctly.
Old Jul 28, 2019 | 02:23 PM
Hammerhead Fred
The exhaust parts are available in both 2.5 and 2.0 inch diameters. You need to determine which system you have before purchasing.
Old Jul 28, 2019 | 02:31 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
also this is a VERY common part found at any auto parts store or exhaust shop
Old Aug 24, 2019 | 12:50 PM
Pitts532M's Avatar
Pitts532M
no sleeve for the doughnut, bad seal. Got her with properly attached now. Thank-you.
Old Aug 26, 2019 | 01:10 PM
carriljc's Avatar
carriljc
Pitts532M
Take a look here.... I did this replacement last year... you should really use the SLEEVE per Willcox.... otherwise it looks like you'll burn up the donut (packing).
https://www.corvetteforum.com/forums...downpipes.html
To C3 72 exhaust donut ?
