Newb with engine wiring question
Old Jul 26, 2019 | 11:15 PM
vette-ish's Avatar
vette-ish
Default Newb with engine wiring question
I've been struggling to find any good resources for the engine wiring. I bought my first Corvette, an '81 C3, in the past week. A decidedly uninformed purchase, but it's too late now.
I've been looking around the engine compartment and found a wiring harness with four disconnected connectors. The only thing connected is a ground to the Edelbrock intake manifold and what I assume to be the air intake temp sensor in the manifold. The sensor looks like it should be replaced, but I'm also wondering what is missing/not connected.
Here are images of the connector and wiring harness:
https://imgur.com/a/R0SyZFC
Any help would be much appreciated!
Old Jul 28, 2019 | 01:30 AM
Antz81's Avatar
Antz81
Those connectors are part of the original CCC system. Which had a computer controlled carb with electronic advance on the distributor. Seems like the carb and distributor have been replace so these are no longer required. There should be a couple of 6pin plugs near the rear of the engine on the passenger side you can use to remove this unnecessary wiring.
Old Jul 28, 2019 | 02:02 AM
vette-ish's Avatar
vette-ish
Thank you Antz81!
To Newb with engine wiring question
