1976 Corvette
Old Aug 9, 2019 | 11:21 AM
Montobeen1's Avatar
Montobeen1
5th Gear
Default 1976 Corvette
Hi,
Should I be using octane 90 in my 1976 corvette?
Old Aug 9, 2019 | 11:28 AM
This should be asked in the C3 section, so off it goes.
Old Aug 9, 2019 | 11:32 AM
ntfday's Avatar
ntfday
Veteran: Marine Corps
Originally Posted by Montobeen1
Hi,
If it's stock, no, 87 will be fine.
Old Aug 9, 2019 | 12:02 PM
Montobeen1's Avatar
Montobeen1
5th Gear
Default 1976 corvette
I'm not very technical but the engine has a lot of modifications, so I don't think it's stock
Old Aug 9, 2019 | 12:05 PM
ntfday's Avatar
ntfday
Can you get some engine specs from the builder? For the most part 87 octane gas is good to about 9.5 to 1 compression ratio.
Old Aug 9, 2019 | 12:11 PM
OldCarBum's Avatar
OldCarBum
My 73 has the mostly stock 454 big block.
It would run fine on 87 octane, but I put the premium 91 octane in it, just because.
Old Aug 9, 2019 | 12:17 PM
Montobeen1's Avatar
Montobeen1
5th Gear
My mechanic is putting new spark plugs in and he mentioned it may run better with ethanol free gas
Thanks for welcome everyone!!
Old Aug 9, 2019 | 12:45 PM
HeadsU.P.'s Avatar
HeadsU.P.
Where do these non-knowledgeable mechanics come from?
No, you don't want that stuff at what, $1.50 more than premium? Nonsense. For your last tank full of gas for the season then yes, it stores very well.
The proper way to determine octane needs w/o knowing engine data is to start with the highest octane available. Next fill up, drop down a notch by mixing a half a tank of mid-grade and half premium and monitor pinging. If it still doesn't knock, drop down to full tank of mid-grade and so on. You have to listen to the engines needs.
Old Aug 9, 2019 | 02:01 PM
Montobeen1's Avatar
Montobeen1
5th Gear
Thanks. I thought ethanol was not good for older engines. is that not correct?
Old Aug 9, 2019 | 02:39 PM
ntfday's Avatar
ntfday
Ethanol is NOT GOOD for any engine and if it wasn't government subsidized it would go away.
Old Aug 10, 2019 | 07:35 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
If you live in a state that has ethanol free gas and its not ridiculously expensive, I would go with that. My friends in Utah say some of the chain Food/gas stations carry it with no mark up
Old Aug 10, 2019 | 08:58 AM
Montobeen1's Avatar
Montobeen1
5th Gear
Thanks!!
To 1976 Corvette
