New 1968 427 Wiper Issue
Just got this 1968 and starting to go through the "to do" list. After finally releasing the frozen wiper door, I'm at a loss as to why the wipers won't park or at least go down manually. Wiper switch appears dead, wiper door non-functional. (Appears all new vacuum hoses all replaced). I might be crazy but I see only 1 over ride pull down under the dash. I push it up and it seems to float back down alittle. I am familiar with the 3 functions of the under steering wheel over rides on later years...
Why can't I get the wiper arms to go down by hand? I don't want to force them...
Here you can see the "worm" that is on the motor shaft itself
it runs against the outside of the large gear and when the motor spins it pulls the gear around, almost like threaded a bolt into a nut pulls the nut down
so when you are trying to push the wipers down it's trying to turn that gear and get the worm to spin... like trying to push a nut onto a screw and getting the screw to spin...
anyway, if you just want the wipers out of the way for now, pull the arms off the splines on the transmissions (little clip underneath) or you'll need to pull the motor and disconnect the wiper arms (or remove the grill part and you can get at them there)
HIH
M
There is a 12 volt dc motor in the Windshield Wiper System and it provides the mechanical forces needed by the back and forth action of a windshield wiper system. To test this system get the parts engaged by activating the wiper switch usually gets the cover up automatically using only the vacuum in the system. On my old C3 I have two pull down valves and a **** that turned. The One **** made the wiper cover rise, The second one made the headlights come out the **** would disconnect the power going to the windshield wipers allowing a new owner to change the wiper blades.
Once my car calms down after running for a short bit it has good vacuum in the canister the headlights or the windshield washer cover used to "launch" up into place. Don't force the vacuum operated systems by hand, use a good source of vacuum. It was looking to be a challenge to get to the wipers again on my early 1968 Corvette. After some inspection I found loose Rubber vacuum lines and so I replaced the lines and the check valve assembly just to be safe. Once again the vacuum systems operate quickly and smoothly. Even with a "worked on" 427 Big block with high compression I get 16-18 inches of vacuum in my system.
For the first 10 years after the Complete Vacuum Hose set was installed professionally the headlights would pop right open and the vacuum was there for weeks. That was a while back and Corvettes@Carlisle is next weekend and 103 miles away. I have learned and saved so much from the Corvettes @ Carlisle experience. If you know what you want they will even bring it out for you. I need to visit Dr.Rebuild and Al Knock, I need a replacement Convertible top. It will be another winter project I hope. I have the abilities to sand blast and powder coat here in my garage. I have needed a good excuse to paint the hardtop for my 1968. The car is Daytona Yellow with a black convertible or a black painted hard top. I have thought of painting it all to match, it certainly needs it. But my flying instructor told me so wisely that (Paint Don't Fly) how it ran was all he wanted to know.
I hope that you get your vacuum system sorted out easily! I am hard of hearing (To say the least) so I can't hear the vacuum leaks that many of you can hear. It makes life a bit more challenging. Those of you who can hear properly, I envy you. It is one of the most important senses I miss.
Best regards,
Chris
