AC compressor brackets???
Old Aug 17, 2019 | 10:48 AM
houstcool's Avatar
houstcool
6th Gear
Default AC compressor brackets???
Hello! I am currently trying to put a 400 Sbc into my 74 Vette. The problem I am running to is the mounting brackets for the AC compressor are set up for the driver side but the car has everything on the passenger side for AC. Any suggestions?
Old Aug 17, 2019 | 12:32 PM
MelWff's Avatar
MelWff
Is buying the correct brackets an option?
https://www.zip-corvette.com/68-82-c...-mounting.html
Old Aug 17, 2019 | 12:36 PM
houstcool's Avatar
houstcool
6th Gear
The 400 doesn’t have the same holes tapped as the 350. Also it’s a compressor that came with the 400 Sbc. So the brackets fit great and the compressor will work it’s just on the side. Plus I don’t have three threaded holes on the passenger side of the heads. Only the driver side.
So would it be worth it to tap new holes on the passenger side of the heads?
Old Aug 17, 2019 | 01:45 PM
bikesnbroadheads's Avatar
bikesnbroadheads
you need to look at another sbc car and see how the compressor is mounted on the pass. side. my 71 the front bracket is on the 2 water pump bolts and the rear bracket is off the ex. manifold bolts. if you have a stock a6 compressor you should be able to make it work on the pass. side with the correct brackets.
Old Aug 17, 2019 | 01:59 PM
derekderek's Avatar
derekderek
That bracket setup is also for the long water pump. What came out of that engine compartment? The 350 compressor and brackets should fit the 400.
Old Aug 17, 2019 | 02:39 PM
houstcool's Avatar
houstcool
6th Gear
I can’t tell you what came out of the car. It’s been sitting in a field for 30 years. Which is longer than I’ve been alive. I got ahold of a 400 Sbc for it from someone else’s project truck.
Ill take a look at some other sbc cars to see what they’ve got on them.
Old Aug 17, 2019 | 03:01 PM
houstcool's Avatar
houstcool
6th Gear
I just looked around online at other set ups for Ac brackets in cars and vettes. I can make it work with the right brackets! Thanks for Y’all’s help!
Old Aug 17, 2019 | 07:58 PM
derekderek's Avatar
derekderek
maybe time to upgrade to proper 134 style. brackets, hoses, VIR elim... https://www.ebay.com/itm/73-77-CORVE...kAAOSwtQNb7EE9
Old Aug 17, 2019 | 09:15 PM
Street Rat's Avatar
Street Rat
Default Source for Brackets
Check these guys out. They make brackets for darn near anything. Alan Grove Components
http://www.alangrovecomponents.com/Catalog.htm
To AC compressor brackets???
