1968 antenna hole location
Old Aug 27, 2019 | 08:16 AM
68ssconv's Avatar
68ssconv
Default 1968 antenna hole location
Can anybody give me the antenna hole location on a 68 vert. I need to drill it. I did a google search came up empty. Thanks
Old Aug 27, 2019 | 12:06 PM
ronarndt's Avatar
ronarndt
See if this helps. There should also be a grounding plate on the inside surface of the fender. See if that is there and use it to locate the hole.
Old Aug 27, 2019 | 12:22 PM
68ssconv's Avatar
68ssconv
thanks that will work
Old Aug 27, 2019 | 06:50 PM
loup68's Avatar
loup68
Army
Just a heads up. The 68 chrome antenna nut is a one year only item and to my knowledge, no one is reproducing it. The ones for sale are for the C-2's and the antenna mast will tilt forward.
GM changed the antenna in 1969. Lou.
Old Apr 3, 2024 | 11:40 AM
c1nicole's Avatar
c1nicole
Having to drill one out as well.
I can see where the hole is but had to be fiberglassed on the underside.
Looks to be a larger hole with a smaller part to accept the tab. What size did y’all use to drill this out?
Also the retainer is in terrible condition. @loup68 mentioned these parts are hard to source.
Old Apr 3, 2024 | 02:24 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
super old thread, but if you still looking to drill it ................
................just a little past the "TAINT"
Old Apr 8, 2024 | 08:50 AM
c1nicole's Avatar
c1nicole
Will confirm with my anatomy book where that is.
Since this is an old thread, have any of the aftermarket sellers made a retaining nut that actually fits? #1691?
Old Apr 8, 2024 | 08:54 PM
loup68's Avatar
loup68
Army
I think that I goofed in the above post, it is the chrome angled bezel that is different. They sell only one from 63-68. But the shape of our body is different than the midyear cars.
This is the part that is not reproduced, not the nut. Lou.
Old Apr 8, 2024 | 09:09 PM
Bikespace's Avatar
Bikespace
Before you drill, have you considered a hidden antenna? Or, perhaps, no antenna at all?
An XM antenna can lay on your dash, and your phone has all the antenna it needs already.
How hard would that adaptor piece be to 3D print, if you do end up drilling a hole and needing it?
Old Apr 10, 2024 | 05:01 PM
c1nicole's Avatar
c1nicole
I did consider that but it was not fully filled in so plan to install my antenna. I DO hate threading it through my car cover.
I think it looks great without but will stick with it for cost sake.
To 1968 antenna hole location
