Lifting options.
Old Aug 29, 2019 | 05:08 PM
Nosheruk's Avatar
Nosheruk
Default Lifting options.
I cant justify the cost of a quick jack, but have found a decent qualitly low, long reach jack that can raise the car on eithet of the points in red on the pic one at a time.
This would safely allow the car to have either the front or rear raised without any frame twisting and also allow jack stands to be fitted in the reccomended points.
Thoughts?
Old Aug 29, 2019 | 05:30 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
use a block of wood on the front cross member to prevent it from damaging it
Old Aug 29, 2019 | 05:36 PM
Nosheruk's Avatar
Nosheruk
I was actualy thinking of getting a block of wood with a curved cut out to match the crossmembers 👍😎
Old Aug 29, 2019 | 05:57 PM
Nowhere Man
A simple 2x6 wide enough to brace the cross member will do.
Old Aug 30, 2019 | 08:19 AM
augiedoggy's Avatar
augiedoggy
The front lift area on my 74 is all dented in for some reason and I havent been able to figure out how or why myself..
Old Aug 30, 2019 | 05:51 PM
Nosheruk's Avatar
Nosheruk
There are a few scuffs on mine in the areas in red so i guess its a common safe place to lift 😎
Old Aug 30, 2019 | 05:59 PM
Mooser's Avatar
Mooser
The metal in the center of the front crossmember is not strong enough to lift the car from, especially with a typical small cup floor jack that most people tended to have. The front and rear edges of the crossmember are lots strong but that middle area isn't. There is a tool available to straighten out the crossmembers that have been all bent up (I made mine, it's still out somewhere on loan hopefully making it's way back at some point https://www.corvetteforum.com/forums...mber-dent.html )
Just search front crossmember dent for examples
Spanning the area front to back with something (2x6?) so it's actually resting on the edges should be OK, spread the jack area out to the front and rear of the crossmember
M
Old Aug 30, 2019 | 06:34 PM
Nosheruk's Avatar
Nosheruk
M
Fantastic answer Mooser.
Thanks for your input 😎👍
To Lifting options.
