Fuel line 75 model
Old Sep 2, 2019 | 11:06 PM
dc6902's Avatar
dc6902
Default Fuel line 75 model
Would anyone know whether the fuel on a 1975 model is metal from the fuel tank all the way to 6 or 7 inches from the fuel pump? I'm trying to replace all rubber in the fuel system.
Old Sep 3, 2019 | 03:39 AM
Kie's Avatar
Kie
Yes it is. Or rather... yes they are. A 75 has a steel supply line and steel return line from the tank to the fuel pump area. I’ve seen some here refer to the return as a “vapor” line.
Old Sep 3, 2019 | 07:54 AM
dc6902's Avatar
dc6902
Thank you
Old Sep 3, 2019 | 05:48 PM
bazza77's Avatar
bazza77
pretty sure the 75,s had 3 steel lines , two on the passenger side ,one supply, one return . On the drivers side it had a line from the tank to the charcoal cannister, this line was the tank breather or sometimes "vapour" line.
Old Sep 3, 2019 | 06:36 PM
60 SHARK's Avatar
60 SHARK
Correct,,,,
Old Sep 3, 2019 | 06:39 PM
60 SHARK's Avatar
60 SHARK
I believe you will want to drop the tank to easily replace the rubber hoses on top of tank,,,, ( you likely knew that thou,,,,
To Fuel line 75 model
