68 frame adding kick up gussets
Old Sep 9, 2019 | 06:56 AM
dave19054's Avatar
dave19054
8th Gear
Default 68 frame adding kick up gussets
I have a early 68 frame and I am adding the gussets to the frame and need some dimensions, does any have the correct measurements.
Old Sep 9, 2019 | 08:12 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Same question for me...I'll do a forum search .
I couldn't find any pics in search, I found this on web......
you can use ratios to determine position of gussets.....bottom of gusset overlaps frame hole/top of gusset is at kickup frame hole....I'm guessing the gusset is 2" x 2" heavy-wall mild steel square tubing
Old Sep 9, 2019 | 08:33 AM
davidchristopher's Avatar
davidchristopher
Are they the same as on a '69? I'll take a pic of my frame when I get in tonight.
Old Sep 9, 2019 | 08:50 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by davidchristopher
...Are they the same as on a '69?...
Yes.
Old Sep 9, 2019 | 12:01 PM
L-46man's Avatar
L-46man
You might want to consider 'going the extra mile'.
The Frame is out and accessible.
Notice how Chevy 'stitch-welded' the frame? You might want to consider continuous welding it. With out pouring untold extra heat into it...(Patience).
this WILL make it stronger.
Good luck.
Unkahal
Old Sep 10, 2019 | 03:03 AM
SB64's Avatar
SB64
Had to repair the upkick rails on my 69. It is a good idea to go over the entire frame while it is open. Maybe a little overkill but I wanted these rails to be as strong as I could make them. Also used a few or the after market frame replacement parts which fit like crap but can be modified. Also added new cages and nuts while at it.
ZIO
Old Sep 10, 2019 | 03:10 AM
sug's Avatar
sug
2020 Corvette of the Year Finalist (stock)
C3 of Year Winner (stock) 2019
Nice looking welding Zio ,that's not going to move or flex at all
Old Sep 10, 2019 | 06:18 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I wanted to go this route if I ever get my body and frame seperated
Old Sep 10, 2019 | 10:14 AM
Rodnok1's Avatar
Rodnok1
That's a stout looking setup. Any more info on it? Thanks.
Old Sep 10, 2019 | 11:27 AM
Rescue Rogers
I got it from a story.
https://www.chevydiy.com/c3-corvette...-modification/
Old Sep 10, 2019 | 11:36 AM
Rodnok1's Avatar
Rodnok1
Thanks man, all the articles I've read don't think ever saw that one.
Old Sep 10, 2019 | 10:19 PM
davidchristopher
Here ya go - frame came from a '69. I did have to repair parts of it but I'm certain it's straight. I make the gussets out to be 12" out and 12" up.
Also added the triangle-parts to the post here - which I believe are "6 in and "6 forward.
Old Sep 11, 2019 | 12:12 AM
reno stallion's Avatar
reno stallion
C2 of Year Finalist (appearance mods) 2019
I think the gusset is to wide will hit floor not sure. but welding the frame is good idea
Old Sep 11, 2019 | 02:53 AM
SB64's Avatar
SB64
Well done, and also some very nice welding!
ZIO
To 68 frame adding kick up gussets
