c3 rear hub removal problems
Old Sep 19, 2019 | 06:04 PM
Dwhit's Avatar
Dwhit
2nd Gear
Default c3 rear hub removal problems
Hello,
I am trying to install a new ridetech suspension on my '78 vette and can't get the old rear hubs or rotors off of the trailing arms. Is there a hub puller or technique besides banging the S*%t out of it??
DW
Old Sep 19, 2019 | 06:14 PM
Kevin68's Avatar
Kevin68
Are these the original rotors? Have you drilled out the rivets that hold the rotor on?
Somebody correct me if I'm wrong, but I think the bearing assembly has a flange that is bolted to the TA, 4 bolts, accessed from under the car after you remove the half shaft. Easier to access with the TA removed. Now would be a good time to replace the TA bushings. It's been several years since I did that job. I don't recommend beating on them.
Old Sep 19, 2019 | 07:36 PM
derekderek's Avatar
derekderek
the bearing assy requires a press. you can't get en with bfh or 3 jaw puller. buy special tools that are more than trailing arms or have them done or replaced.
Old Sep 19, 2019 | 09:01 PM
davidchristopher's Avatar
davidchristopher
I'm doing mine myself, cos why not? The link above isn't mine, but it's a method similar to what I'm doing.
Old Sep 19, 2019 | 09:12 PM
davidchristopher
Got to thinking about it - you should be able to get the rotor off - so I'm wondering if your e brake is binding? Did you back it off?
Old Sep 19, 2019 | 10:11 PM
lowbuck72's Avatar
lowbuck72
When I did mine I purchased a spindle knocker. Hammered on that damn thing for what seemed like all afternoon, but it came off. No damage except the tool looked like it belonged in a mushroom garden.
Old Sep 20, 2019 | 06:39 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
If the rivets havve been drilled out and the rotor is off, then its probably just the parking brake grabbing on the inner surface. Jusst adjust them all the way in to the loosest setting an dthey should come apart. Take pictures of the parking brake assembly to assist in putting it back together correctly provided they are working and adjusted correctly now
Old Sep 20, 2019 | 08:15 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
EDIT....if there's a way to access the old issues of 'Corvette Fever' magazine, they did a very thorough article, back in the mid-1990s, on how to rebuild the rear wheel bearings on a C-2, C-3. That was my reference, when I rebuilt the t/a on the '79 that my wife used to own.
Last edited by leadfoot4; Sep 20, 2019 at 08:18 AM. Reason: additional information
Old Sep 20, 2019 | 10:55 AM
GTR1999's Avatar
GTR1999
That YouTube video is NOT how you want to setup rear bearings
Old Sep 20, 2019 | 10:56 AM
GTR1999's Avatar
GTR1999
This is the best way to remove the axle. A 5lb mini sledge and a few wacks will get them out. If the tool doesn't easily screw on the axle you have thread damage that you have to correct or replace the axle.
To c3 rear hub removal problems
