Same shaft size. I guess it depends on the clutch. The ones at ecklers seem short also.
Experts,
The throw-out bearing I want to install is the right shaft size however the height of the bearing is much shorter. Will this cause free play in the clutch or bind? Little guy on shoulder said abort abort.
