Screw size
Old Sep 23, 2019 | 08:28 PM
croaker's Avatar
croaker
Default Screw size
Does anybody know what size screw holds drivers side mirror on 1975? I picked up 10 /24 but they don’t seem to thread. Anybody know?
Old Sep 23, 2019 | 09:40 PM
Mooser's Avatar
Mooser
Everything I've got say #10-24, maybe the threads just need to be chased?
M
Old Sep 23, 2019 | 10:04 PM
croaker's Avatar
croaker
Yes maybe. The screw I took out looks to be a 10/24 but gets real tight after about a thread. Thanks for your reply
lowbuck72's Avatar
lowbuck72
10-24 seems kinda coarse for automotive applications, Just for fun try a 10-32.
Old Sep 23, 2019 | 10:07 PM
croaker's Avatar
croaker
Will do. I guess no 10 28 in machine screws?
Old Sep 23, 2019 | 10:16 PM
Mooser's Avatar
Mooser
nope, 10-24 then 10-32, not even a close metric size for a #10
M
Old Sep 24, 2019 | 07:18 AM
derekderek's Avatar
derekderek
10-24 are bumper cover mount screws. GM wasn't real big on fine threads except flywheels, balancers and stuff. phone cameras are pretty good. try to get a pic of female thread. you sure it is a machine and not sheet metal thread?
Old Sep 24, 2019 | 08:27 PM
gbvette62's Avatar
gbvette62
The original driver's side mirror mount screw was a special 10-24 screw, with a #8 head, but any 10-24 machine screw with a countersunk head should work. The same screws were used for the rocker panels.
10-32's were used with the Well Nuts, used to install the passenger side mirrors.
Old Sep 24, 2019 | 11:38 PM
croaker's Avatar
croaker
Ok guys this is how it turned out I ran a 10 24 tap in front hole but it was to big for the second. They had a sheet metal screw holding it on with probably some kind of glue. I was able to run a 8 32 tap in and same size machine screw. I didn’t’ Want to get the drill around the fresh paint if possible. Thanks to all who replied.
To Screw size
