Harness needed clutch sensor?
Old Sep 25, 2019 | 07:09 PM
Alanmiles's Avatar
Alanmiles
Default Harness needed clutch sensor?
Doing an auto to manual swap. Is there a separate harness needed to connect the clutch position sensor to ? Thanks!
Old Sep 26, 2019 | 06:47 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
What are you calling a "clutch position sensor"?
Old Sep 26, 2019 | 02:20 PM
bradleyb66's Avatar
bradleyb66
There should be connections for both the auto (neutral safety switch) and the standard (clutch safety switch) already in the wiring harness. However, the clutch safety switch has a small 'dongle' that converts the pins on the switch to the connection on the wiring harness (at least my 69 had the dongle). I'm not sure if the dongle will be present on the wiring harness.
Old Sep 26, 2019 | 05:55 PM
TimAT's Avatar
TimAT
I put new Lectric Limited harnesses in my 69. The clutch switch connector was taped to the dash harness and the NSS for the automatic was running with the heater connectors to the center.
To Harness needed clutch sensor?
