Tune Up
https://www.rockauto.com/en/catalog/...park+plug,7212
AC Delco R45TS Plugs.
https://www.rockauto.com/en/catalog/...+wire+set,7224
AC Delco 608D Ignition wires
https://www.rockauto.com/en/catalog/...butor+cap,7120
AC Delco D336X Distributor Cap
https://www.rockauto.com/en/catalog/...tor+rotor,7136
AC Delco D448X Rotor
I use the OEM parts for the cleanest and most original look. No measuring wires.
Differential oil for your specific differential
Automatic Transmission fluid and filter for your year car
or
Manual transmission oil for your gearbox
Siphon brake fluid from reservoir and refill with new fluid/you could gravity drain one caliper at a time until clear fluid came out off bleeder
Engine oil & filter
Coolant
Grease all suspension parts
Grease all u-joints
Replace grease in front wheel bearings
(Rear wheel bearings are a PAIN until you repack them the first time)
Grease or lubricate all cables, door, decklid, hood latches with appropriate grease or oil or graphite
Other members can advise you about your other questions.
I run Taylor Spiral core wires and there are more expensive but unless you have a race only car they're unnecessary. I don't like OEM because they are cheaply made and prone to failure.
I would buy the highest dielectric strength cap and rotor available since the cheap ones are prone to arcing which might require MSD as I don't know who makes Standard Products at this time.
I am running E-3 spark plugs in my 76 and am very happy with them.
or
Engine oil & filter
Coolant
Grease all u-joints
